Best way to adjust TA headlights?
Old Apr 6, 2005 | 11:10 PM
Nick D's Avatar
Default Best way to adjust TA headlights?
Ever since my passenger side headlight and front bumper got tapped, it pushed the headlight assembly back a little and now I am having issues with the passenger side light not wanting to pop up. It's because it is rubbing on the hood. Any suggestions because I don't want to bring it to a body shop because I know I will get raped. Thanks. Pics would be great too if possible.
Old Apr 6, 2005 | 11:43 PM
6']['9's Avatar
the cover to the light comes off and you can adjust it. id do that first if that doesnt work then that whole black assembly that holds the light will adjust as well so try messing with that.
Old Apr 7, 2005 | 12:52 AM
Tech's Avatar
Open the headlight and firmly pull the cover in the direction needed. There are small tabs on there that will allow for adjustment.
Old Apr 7, 2005 | 10:57 PM
silver98formula's Avatar
There are 2 10mm bolts that will allow it to slide forward and back. There are also a bunch of asjustments for the alingment of the headlight door.
Chris
