Help! Trying to remove Painted on Pinstriping
Old Jun 14, 2005 | 04:08 PM
MightyBobo's Avatar
Exclamation Help! Trying to remove Painted on Pinstriping
OK, Im finally killing my painted pinstriping the original owner of the car got. The other day I had to take an extended trip with it, and when I got back I sprayed wherever heavy bug juice was with some degreaser. While I was washing it I noticed some of it was flaking off (not in large ammounts though). Is there any product that might help remove it any faster/cleaner at all? Ive been tempted to wet sand it, however, if it was flaking off simply due to some degreaser and a sponge...has to be a better way...
Old Jun 14, 2005 | 04:38 PM
stryker14's Avatar
I think your best bet would be to just wetsand it off and buff it all out.
Old Jun 15, 2005 | 08:47 AM
MightyBobo's Avatar
Alright man, was beginning to think the same thing yesterday. I already grabbed a 1500 grit 3M Wetordry sandpaper to get it off - hopefully it'll work out alright.
Old Jun 15, 2005 | 10:23 AM
Charging TA's Avatar
Pressure washer... If you want I can show you pictures of my Charger how I got ALOT of the paint from the engine bay to come off with just the pressurer washer alone... it flaked off in peices, so it should work with yours...
Its the first thing I suggest before going with anything abbrasive or chemical. If possible start off with a not so powerful setting (or from a distance), try different angels, but dont damage your body panels.
Old Jun 15, 2005 | 11:36 AM
PendragonZ's Avatar
Chop-Foo Director
Are you sure it's painted on? If it's from the factory it should just be vinyl stickers. Mine came right off, used a little goo gone on the sticky residue.
Unless of course the original owner actually had it painted on...then you need to wetsand like previously mentioned.
Old Jun 15, 2005 | 03:05 PM
MightyBobo's Avatar
Yup, in New York, if you want it when you purchase the car new, almost all pinstriping is actually painted on where I am from (Buffalo). My dealership that I worked for before, would do nothing BUT painted pinstriping, and this one Im 99.9% sure, was sold at the dealership I worked for heh.
Anyway, will probably be trying the wetsanding tonight on it.
