halo wiring instructions?
Old Jun 23, 2005 | 11:26 PM
chon79's Avatar
Default halo wiring instructions?
i tried doing a search but i had no luck....i wanted some kind of instructions on getting the wires into the car without having to drill any holes, or running along through the hood and door... pics would be a great help. thanks in advance
Old Jun 24, 2005 | 08:12 AM
Dustin's Avatar
You shoudnt drill anything. You wire them to your foglights so you can push the foglight button to make them come on or you can wire the power and ground and run another wire to the inside though the hole on the passenger side behind the ecu(which you have to pull out), there will be a rubber grommet, just push it through there.
