Proper way to paint a trailer?
What we do is grind away the biggest rust spots and then spray Rustoleam gloss black paint, just thin it down using some thinner and use a cheap-o gun to spray it... Or you can do it with a brush, just make sure it goes on thick, and dont do it right before nighttime cause the moisture will cause "dull spots"...
Heres how the same paint came out on my 73 Charger front suspension...
