How to remove headlights?
Old Jul 3, 2005 | 01:34 AM
AnimalSS's Avatar
Default How to remove headlights?
Does anyone know if there is a thread in here somewhere that illustrates how to remove headlights on a '00 Camaro? Or, can someone just post the info?
Old Jul 3, 2005 | 03:51 AM
CONVERTED's Avatar
I've looked at them and if you look at them with hood popped you should see the bracket that holds them in.. should be a 10mm like everything else.. upbolt everything you can visually see and then tug on the light.. feel for tension.... but these lights should be cake to get out compared to a T/A and I can pull mine in less than 5 mins...
Old Jul 3, 2005 | 05:10 AM
Black98Z28's Avatar
yep there are 2 bolts maybe 3 i forget, but after its loose u pull it out at an angle same way u put it back in.
Old Jul 3, 2005 | 09:39 AM
Charging TA's Avatar
This goes for pretty much all headlights, dont try to remove the headlights by unscrewing the adjusting screws:p
Old Jul 3, 2005 | 10:17 AM
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
Yeah I did that when replacing a blown light in my 'bird. I felt really stupid when I realized what I was doing...
Old Jul 3, 2005 | 10:53 AM
But it taught you to always double check right?:p
