sequential tails
Old Sep 7, 2005 | 12:36 PM
AltrdPrcptn's Avatar
Default sequential tails
i just emailed the guy from brents website about sequential tails and it seems as if he doesnt make the kits anymore. does anyone know where i can get ahold of a sequential taillight kit or does anyone have a list of the parts i need to make one myself. thanks in advance
Old Sep 7, 2005 | 01:04 PM
EVIL TA's Avatar
go to google and do a search. it helped me and they're cheap. good luck!
Old Sep 7, 2005 | 02:14 PM
darkecho's Avatar
i have some i am thinking about getting rid of let me know if you cant find any
Old Sep 7, 2005 | 05:01 PM
kraaazymike's Avatar
http://www.signalwavelights.com/main.html
This guy from Fbody.com sells them for $80.00
Old Sep 7, 2005 | 09:55 PM
anyone use the ones from signalwavelights.com ???????
Old Sep 7, 2005 | 10:17 PM
1 BLOWN V8's Avatar
Can you get a ticket for this mod?
Old Sep 7, 2005 | 10:19 PM
Pewterpower's Avatar
Yup. I got 'em and I luv them.
The guy's name is Brian and he's awesome to work with. He won't leave you hanging if you have any problems.
Old Sep 8, 2005 | 07:23 AM
NBM7278's Avatar
Thats the kit that I have as well. No problems, easy to hook up, and no tickets. The older cougars had the sequential taillights from the factory. A cop may pull you, but the ticket shouldn't stand. I've passed many cops, using the signals to move back in front of them, and no problems yet.
 Michael S. Palmer
Old Sep 8, 2005 | 12:37 PM
InfiniteReality's Avatar
Got mine for cheaper and from a non-sponsor link. Work flawlessly and lifetime warranty. No cop problems either. IMO I use my signals more than before the sequential lights cause I want people to notice them.
Old Oct 29, 2005 | 05:03 PM
i finally received my kit from signal wave...how long does the install take on average...i have the extra wire and everything here so...jus the install itself what kind of time frame r we looking at?
Old Oct 29, 2005 | 05:12 PM
I'd say 2 hours. Wiring is easy, the time consuming part is drilling out the hole for the new socket. Gotta get it to have nice tight fit so no water leaks inside!
Old Oct 29, 2005 | 09:19 PM
NBM7278's Avatar
I don't think the one from signal wave required any drilling. I just had to cut and splice some wires. Shouldn't take too long at all.
Old Oct 30, 2005 | 08:54 AM
Do you have a link? T/A's have only 2 brake light bulbs per side, you'd want a 3rd one to get the full effect of the sequentials.
Old Oct 30, 2005 | 09:19 PM
Not true. There are 3 on each side, but the one on the outside is a small bulb. You can use a bigger bulb to replace it with (the ones from the Stop light in the spoiler will work perfectly) and it will look alot better in the daylight.
Old Oct 30, 2005 | 09:45 PM
The 194 outside bulb is only a running light the 2 other 3157's are both running and brake lights.
Old Oct 30, 2005 | 09:49 PM
Whatever you want to call it....but it is the 3rd light in the tail light, and is designed to work with the signalwave board as the third light.
I understand what you're saying. By replacing it with the "brake" bulb and socket, it will be much brighter. But you can much more easily just put in the bigger bulb (the ones from the stop light have the exact same blade, but the bulb is twice as big) it fits and works just fine.
Old Oct 30, 2005 | 09:58 PM
Sorry for the poor pic...
The small bulb is the 194, which is the outer most bulb in the TA brake light assembly.
The bigger bulb is from the stop light in the spoiler. You can use this bigger bulb in place of the smaller 194 bulb.
Old Oct 31, 2005 | 12:47 PM
NBM7278's Avatar
Sorry about my delay in getting back to you infinite. Looks like they got you covered on your question though.
As far as the bulb though, I'm not sure what bulb I used. The directions that were sent with the kit recommended a bulb from NAPA and I just bought what they suggested. Once you wire up the kit, all three lights will work for the turn signals. Basically, the input for each bulb will be coming from the board. The input to the board will be just one of the original "hot" wires for the turn signals.
