how to debadge
Old Sep 7, 2005 | 05:58 PM
layz's Avatar
Default how to debadge
i was wondering what to use to debadge my z28 without scratching the paint. anybody have any ideas please help.
Old Sep 7, 2005 | 06:16 PM
sunsetta's Avatar
I did it this past weekend. Thin nylon fishing string works good, sliding it under the emblems. As far as the adhesive, use 3M Adhesive Remover put on with a small brush, and let it set, then use a credit card to scrape it off, NOT A RAG, it will gum up if you rub it.
Old Sep 7, 2005 | 06:19 PM
AntiVenom06's Avatar
I used fishing line.
Old Sep 7, 2005 | 06:52 PM
2000blackta's Avatar
fishing line here as well, but i also used a hair dryer to loosen the adhesive. It seemed to make the line cut through much easier.
Old Sep 7, 2005 | 07:23 PM
2K2WS6TA's Avatar
Fishing line, or dental floss also works, let it sit in the sun all day (if you feel a little silly taking a hair dryer to your car) If you do try to rubthe glue off with your finger you'll have a blister by the time you're done, so use the 3m adhesive remover (much easier
Old Sep 7, 2005 | 07:40 PM
I used a air-powered pin-stripe removal tool on the glue, it worked out pretty well. You can rent them or borrow them from most body shops, gets rid of very quick, took me only 10 minutes or less.
Old Sep 7, 2005 | 08:07 PM
project98LS1's Avatar
i just peeled mine of after letting it sit in the sun, took some wd40 to it and just started rubbing with my finger. it's not the best way, but it worked for me. and yeah..my finger did hurt after that.
