Carbon Fiber Prep
Old Oct 25, 2005 | 05:40 PM
ceo44's Avatar
Default Carbon Fiber Prep
All,
Do you prepare CF the same as fiberglass for painting? Assuming sanding, perhaps a skim coat and maybe some light weight filler for low spots?
Thanks
Old Oct 25, 2005 | 09:38 PM
ceo44's Avatar
Common guys....someone surely has worked with CF
Old Oct 25, 2005 | 10:07 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
Try the search button I did a write up on how to do carbon fiber overlays a while ago
Old Oct 25, 2005 | 11:51 PM
parbreak's Avatar
Don't think he was asking about doing overlays. I think we wanted to know how to paint carbon fiber. Yes, it is prepared the same way fiberglass in prepared. Fill in any pinholes or other imperfections. Prime and paint as you would with fiberglass.
Bryan
parbreak
Old Oct 25, 2005 | 11:57 PM
ChevyChad's Avatar
I think you are correct.
Old Oct 26, 2005 | 06:25 PM
kerryt1's Avatar
Yes, that's true. But, be careful because Bondo will not stick properly to some types of resins. I believe (don't quote me on this) that it will work on a polyester resin, but will not stick all that well on an epoxy resin. I'd have to dig and see if that's the right or if I have that backwards.
Old Oct 26, 2005 | 10:12 PM
parbreak's Avatar
I don't think he would want to use Bondo anyhow. Probably too rough. Should probably use a glazing putty that will smooth out easier.
