PIAA 510 Driving light installation
Is there any way to remove the factory fog lights without having to remove my front bumper.
Any suggestions are welcomed. Thanks
, I just tilted them a little bit forward and then pushed the bumper hole a little bit down and they came right out.Now I have to fix the braket up so the PIAA's fit in it, so far I am thinking of opening the side wings a little bit because the PIAA's two screws that hold the lens won't let the PIAA's fall into place. Then I will have to straighten the bend in the bracket where the factory adjustment screw was in and elongate the hole or I could drill a new hole a little bit lower in the bend.
What did you guys do to make the PIAA's fit in the braket?
Blazingws6kush how did you get the PIAA's in trough the front since the bracket is too big to fit in trough the bumper hole? Did you cut the bracket?
