Show Me You Custom Interior!
Thanks for the compliments. The tach was not too bad of an install, just
a little tight because the windshield is sloping down on top of where you're trying to work. Drilled two holes in the A Pillar trim to attach the tach mount and then drilled another hole in which to run the tach wires. Wires are covered in black loom so it really looks clean and neat. Wires
run down behind the fuse panel and to the appropriate connections.
Bryan
parbreak
Does look good though!
I had a nice Grant shift **** prior to this one, but it was light weight and hollow so it amplified my transmission noise like crazy and had to go.
