Need lowering spring pictures
Old Dec 10, 2005 | 01:10 PM
M6WS6's Avatar
Whose haveing problems scraping ?I know one will have more when lowering, but if its extreme or something.
93formto98T/A
Is that just the springs(height of the car)?Problems with ground clearance a big issue?
Old Dec 10, 2005 | 01:50 PM
phantomzer0's Avatar
how do the cars ride? real stiff? or floaty? also anyone with sub frames, is there any scraping?
Old Dec 10, 2005 | 01:53 PM
M6WS6's Avatar
If they are like my subframe connecters, they are tucked up very nicely. If those touch, then the steel where the side g-effects hook up will scrape. I dont know about your subframes, but mine are hardly seen by looking underneath
Old Dec 10, 2005 | 02:10 PM
M6WS6's Avatar
Also, comments too, what like or dislike.
Old Dec 10, 2005 | 02:16 PM
ta_silver_bullet's Avatar
BMR here i love em
Old Dec 10, 2005 | 02:38 PM
skewba98z28's Avatar
Scraping all depends on your drivind style. I've got a prokit and the only problem I've had was the Y-pipe and the air deflector under the car. No big deal though. With the Intrax's I would say there would be alittle more concern though
Old Dec 10, 2005 | 02:55 PM
yeah i used to have goldline springs(advetised 1.75" drop all around actual 2.25 front 2 rear) pic below:
you can see how low the duals hung to the ground i scraped EVERYWHERE
now BMR one in drop all around:
and now it sits now perfect ride height for me and no scraping
Old Dec 10, 2005 | 05:56 PM
Camaro Z's Avatar
Sportlines
Old Dec 10, 2005 | 06:00 PM
Camaro Z's Avatar
My cars stiffness is a noticible difference from stock springs. Rides a little rougher, but i like it alot. The cornering is hands down is alot better than stock. I recommend Sportlines to anyone.
Old Dec 10, 2005 | 10:29 PM
M6WS6's Avatar
How are the sportlines?Is there alot of ride height diff from the pro?Scrape alot?I like the stance, concerned for my cars bottem..........
Old Dec 10, 2005 | 11:05 PM
Ell Ess Won's Avatar
Camaro Z your stance looks killer....
I'm worried about lowering with my headers....it appears as if the Y-pipe under my car has about 3" of clearance right now at stock height....is it possible to lower?
Old Dec 10, 2005 | 11:33 PM
  #32
M6WS6's Avatar
If you have hookers like me, they are actually the same height, if not tucked up better than stock mani's with y. If you have SLP headers, GOOD LUCK!
Old Dec 10, 2005 | 11:36 PM
  #33
M6WS6's Avatar
Back to the sportlines, anyone having issues with clearance to a point where it is crazy bad?
Old Dec 10, 2005 | 11:43 PM
  #34
Man sportlines are very low Front and Rear. if I had to do it over again I would get DMS
Old Dec 10, 2005 | 11:51 PM
  #35
71camaro's Avatar
I am having alot of scraping problems with my sportlines. Due to a set of headers and a x-pipe. Thus, they are comming off, and Im gonna go with a drag suspension setup next! But i do love the way my car's stance is
Old Dec 11, 2005 | 12:07 AM
  #36
01 Red WS6's Avatar
With my BMR kit I don't scrap at all. The ride is a more firm than stock but I like it a lot
Old Dec 11, 2005 | 12:12 AM
  #37
jargan04's Avatar
I have LT's and ORY. I normally dont scrape with my LG's.
Old Dec 11, 2005 | 06:50 AM
  #38
02_Phase2_ZL1's Avatar
Default Need lowering spring pictures
I am the co-owner of an automotive shop and we use the Eibach Pro-Kit that is built for GMMG, Inc. With the exception of my '02 ZL1 shown below, we have lowered all the other Camaros with this particular Pro-Kit.
This is my 2002 Phase II ZL1 Supercar. GMMG lowered it with the Pro-Kit (as they did with all 2002 ZL1's) when they originally modified it and also added Spoon lower control arm relocation brackets. I have also boxed in the stock lower control arms and added Don Goetz bolt-in sub-frame connectors.
This is my 1997 30th Anniversary Camaro SS convertible. It has also been lowered with the GMMG/Eibach Pro-Kit. I have also added the Spoon lower contol arm relocation brackets, boxed-in the stock lower control arms, added Don Goetz bolt-in sub-frame connectors and replaced the stock 16X8 wheels with the stock 17X9 wheels. SLP would not put 17X9 wheels on the convertibles due to a loss of ride quality because of the shorter sidewall on a P275/40R17 vs. a P245/50R16 tire.
The rest of the photographs below are pics of Camaros we have lowered at my shop with the GMMG/Eibach Pro-Kit.
Hope this helps you in your decision making process ! ! ! !
Old Dec 11, 2005 | 08:20 AM
  #39
DANSBIRD's Avatar
Prokit Springs w/ Bilstein HD shocks... Never scrape either
Old Dec 11, 2005 | 11:52 AM
  #40
same here love the ride and never scrape
