How to bring the luster out of the...
Old Dec 16, 2005 | 01:04 AM
02SilverWS6's Avatar
Talking How to bring the luster out of the...
center tail light plastics.
It's really scratched and I want it to look like new. If it's impossible I'll just buy a new center tail light.
Actually what I mean is the plastic piece where the key hole for the trunk is on my car. That plastic piece is what I want to look shiney.
Thanks!
Old Dec 16, 2005 | 01:09 AM
meissenation's Avatar
you could always try just taking it off, wetsanding it down, then repainting it.
Old Dec 16, 2005 | 01:17 AM
Scotty-Z's Avatar
This might be your best and cheapest option.
Old Dec 16, 2005 | 01:34 AM
Silver02TA's Avatar
no need to bring paint into this...
wet sand it with 600, 1000, and then 2000 grit paper; then use a plastic polish on it
Old Dec 16, 2005 | 07:42 AM
6']['9's Avatar
is this enough lustre...
https://ls1tech.com/forums/showpost....3&postcount=16
Old Dec 16, 2005 | 09:49 AM
jimbonzzz's Avatar
Wet sand with 1000 grit, then 2000 grit, then polish with 3M Perfect-It II Fine Cut Rubbing Compound, then polish with 3M Perfect-It Swirl Mark Remover
Old Dec 16, 2005 | 01:40 PM
PERFECT Z28's Avatar
Originally Posted by 6']['9
Now that's the way to get the job done right.
Old Dec 16, 2005 | 01:47 PM
01pewterbird's Avatar
you could always just try the polish first depending on how bad it is, worked great for mine
Old Dec 16, 2005 | 04:05 PM
PontiacFan's Avatar
You could also use the search function & find all this information, ...
https://ls1tech.com/forums/search.php?searchid=2521950
https://ls1tech.com/forums/search.php?searchid=2521951
I've done literally dozenS of these things, ...
Old Dec 16, 2005 | 05:25 PM
both of those link returns "Sorry - no matches."
Old Dec 16, 2005 | 09:40 PM
PontiacFan's Avatar
Search function is screwed up tonight, as I've been trying to do other searches & it keeps coming up empty or 'Page not found'.
They did work after I posted them tho, as I tried them immediately afterwards.
Lets see if this one works now, ...
https://ls1tech.com/forums/search.php?searchid=2522971
And this one, ...
https://ls1tech.com/forums/search.php?searchid=2522979
Yep, did work for me now.
Someone must have cleared the search history files, ...
