changing interior from gray to black
Old Dec 20, 2005 | 10:36 AM
6']['9's Avatar
Default changing interior from gray to black
is this hard. Im assuming everything should just change out. The guy at the salvage yard said its too hard to remove the dash and install another one. Im keeping the same inside but i just want everything black instead of gray.
has anyone done this or have any suggestions?
Old Dec 20, 2005 | 11:50 AM
meissenation's Avatar
If you're trying to swap the parts, it's not that bad. The only section I'm unsure of is the passenger side dash, I don't know if that actually comes out or not. You can always spray that to match the rest, tho, they have some pretty good paint that matches the stock.
Old Dec 20, 2005 | 01:54 PM
Durien's Avatar
Its not that hard...its just time consuming and requires patience
Old Dec 20, 2005 | 04:19 PM
Luv2spdT/A's Avatar
The dash is the only difficult part because the wiring harness is connected to it. When you go to put it back on it is difficult to put it back on the back side of the dash and tuck everything where it needs to be. But it can be done with a little patience. Other than that it is pretty easy.
Old Dec 21, 2005 | 11:54 AM
janders's Avatar
I have some black sail panels for sale if you decide to do the swap. Let me know.
Old Dec 21, 2005 | 12:47 PM
Racafella13's Avatar
i had tan interior and i swapped it with black carpet and all took me one day to completely swap both interiors between the two cars
Old Dec 21, 2005 | 10:17 PM
6']['9's Avatar
did you do the dash as well or just the carpet/
