Who else has issues with clear side marker lense?
The install was pretty easy, and there really isn't much you can do wrong. The only little snag was getting the old one out. I used the orange bulbs that came with the clears, and I did notice that the bulb clicks in twice to be properly seated. I made a mistake at first on the passenger side with which I started and the blub hung too low causing the plastic at the bottom to crinkle up and melt a bit. I corrected that right away though. Today I look at the other side which had no problems, and still I see some of the plastic crinkling and melting, and this is with only about 40 miles of driving time!
What kind of **** is this? Don't they produce any quality products anymore? Why do they not send a bulb that won't create so much heat, or why don't they use plastic that won't melt from just looking at it hard? This pisses me off!
The other issue I have is that on one of the lenses, the one through which you can see the small bulb, there seems to be a milky film, it's not as clear as the rest of the lens, and not as clear as it's counterpart on the other side.
Grrrrrrrr!
I bet as soon as I wash the car, I will have fish swimming around in all the water that will accumulate in these pieces of ****!
Anyone else have bad experiences?
Manny
That really wouldn't do me much good since I usually just use my car at weekends at night, so the lights have to be on anyhow.
Ah well, they're cheap, once they look to fucked up, I'll just get new ones. Now that I know how to do it, the install won't be hard.
It's still a damn shame that they can't make OEM quality aftermarket parts.
Do those run any cooler than the ones procarparts sends along?
Yea... Thats why I am making my own LED clears. I plan on just clearing my existing side markers, and filling them with LED's...
as for the melting issues i have had that as well. the first two set did melt but i used the bulbs that came with the lenses. on this third set i used led bulbs and have had no problems. i think that the issue with melting is the head from the stock bulbs and the drls being on all the time.
dustin
dustin
Where did you get the LED bulbs from, and do you have a part number?
Thanks!
I did seal up the corners more with silicone, but I left the side markers alone. I'll double check to see if there's any problems in the future, but for now (knock on wood) there's no problems.
Manny
