What kind of direct replacement foglight bulbs is everyone using?
Old Jan 30, 2006 | 04:00 PM
MannyZ28's Avatar
Default What kind of direct replacement foglight bulbs is everyone using?
Since the search still doesn't work for me, I have to resort to making a post about a mundane question like this.
Which foglight bulbs should I stay away from (due to excessive heat and other complications), and which ones give the nicest look and work without any problems?
Thanks for the help, god knows I need it, anyone that watched me install my halos and sidemarker clears knows that
Old Jan 30, 2006 | 04:58 PM
slim0035's Avatar
I use to use the Sylvania Silverstar bulb($20 each, but a lot better light than stock bulb). They kept blowing, along with any bulb I used so I replaced the whole foglight assembly.
Old Jan 30, 2006 | 05:13 PM
MannyZ28's Avatar
Blowing...hm....how long would they last?
And this is for a Z28, just to clarify. Did you have any heat problems with anything melting?
Manny
Old Jan 30, 2006 | 08:26 PM
LS1 Terror's Avatar
i used eurodezins 894 on my 02 Z they are bright white and match my silverstars.got them on ebay for 12.99 plus shipping.
Old Jan 30, 2006 | 08:32 PM
MannyZ28's Avatar
Do they make Silverstars for the Camaro?
Because so far, every person that had Silverstar fogs had a Trans Am.
LS1 Terror,
Did you have any problems with those eurdezins thingies causing too much heat or burning up prematurely?
Thanks!
Old Jan 30, 2006 | 08:56 PM
slim0035's Avatar
My bad I wasnt paying attention to your avatar, I have a WS6. Sorry about that. I am not sure if they make silverstar for the Camaro. They would go out every couple of months and I just got tired of it. The stockers did the same thing as well.
Old Jan 31, 2006 | 09:48 AM
quiet_storm98's Avatar
i have eurodesignz as well..i have only had them in for about 2 weeks and they are alot brighter then the stock ones and are very inexpensive..same for the headlight bulbs..bright and cheap
Old Jan 31, 2006 | 01:26 PM
ncSSu's Avatar
I got the Eurodezigns as well, I have had them for 4 or 5 months and have had no problems.
Old Jan 31, 2006 | 08:26 PM
MannyZ28's Avatar
Well, I bought the 893ST Silverstars, since I saw on a Camaro parts website that that is what they recommend, but I just noticed when I took the stocker out that it is L shaped while the Silverstars aren't. I don't want to rip the package open and try to stick them in just to find out they aren't compatible. The Silverstars are a straight pointing design vs the stock L shaped.
Hmmm...what to do...
This Eurodezigns stuff you can only get off Ebay?
Old Feb 1, 2006 | 03:06 AM
MannyZ28's Avatar
Any ideas?
Old Feb 1, 2006 | 07:24 AM
BAN-LS1's Avatar
thanks i just ordered a set. Do they come with brackets?
Old Feb 1, 2006 | 12:44 PM
The Guz's Avatar
The silver star 893 will fit in. The only thing you will not have is that you will not feel the base of the bulb click like the 894 when it is seated. It will be a snug fit. I have done this and it worked just fine.
Old Feb 1, 2006 | 02:24 PM
MannyZ28's Avatar
Cool thanks, I will try it tonight.
How's your experience as far as the longevity of those things?
Old Feb 1, 2006 | 04:18 PM
baddogz28's Avatar
I'm using the ebay specials too, just put them in though.
Old Feb 1, 2006 | 04:40 PM
LS1 Terror's Avatar
yah manny no problems here. had them on since september. they are the same wattage as the stock ones. they are a blue bulb but burn white. well they say that you can use 881 i think silverstars and they will work for the camaros they have the same bend on the bulb as the 894 i would double check though hope this helps
Old Feb 1, 2006 | 08:13 PM
MannyZ28's Avatar
Ok, I just put those babies in there....not much of a difference if you ask me. Considering that Sylvania lists their light color is 4000k, just as the silverstar headlights, there is still a very noticeable color difference. Hell as far as I am concerned they look just like the stockers.
Not sure where my 43 dollars went!!
Don't buy them!
Manny
Old Feb 1, 2006 | 08:27 PM
LS1 Terror's Avatar
take them off manny and sell those ***** on ebay buy some eurodezins you will love the way they match the headlights besides they are way cheaper
Old Feb 1, 2006 | 08:41 PM
MannyZ28's Avatar
Actually...I just took a closer look and took a picture for comparison.....
Before: Silverstar headlights, stock fogs
After:
Quite the difference acutally. I have been told that the bumper color reflects on the garage door from the fogs, after all my car is red.
What do you think?
Manny
