Brake rotor rust
Properly made sloted/drilled rotors with compatible pads can work fine on our cars. But you're not going to find a setup like that for $160 for a 4 set.
The cheapies (in other words, what 95% of people will buy) are prone crack, promote more dust, and faster/uneven pad wear. It is well known, and there are many examples to be found on this very forum. That is why it is generally recommened to people asking that they stay away from them.
olly
I need to clean up and paint mine also. What is the best way to mask off the "contact" surface of the rotor before painting? I don't want uneven lines from the masking tape.
And as nice as drilled/slotted rotors look...ive seen too many of them cracked, so i just buy the autozone blanks and call it a day
They still show no rust on the out side edges or on the inside drum part.
I brushed them down with a steel wool brush then wiped them down with brake cleaner, then painted them.
https://ls1tech.com/forums/suspension-brakes/893028-work-goes-into-powdercoating-calipers.html
be sure to read the whole thing.
