removing front cover
Pull out the headlights, disconnect the fog lamps from the lenses, and then just go ahead and pull out all the clips/tabs/screws and the front cover will come off. You'll need to jiggle it a little, but it does come off in one piece.
Follow the gaps of the cover and you'll be able to see where it should separate. Just be careful with the clips, they are not exactly a very tough plastic and the edges where you need to slip in a flat blade can bend or break.
I hope you have a grill though, cause otherwise you can see the styrofoam bumper cover through the big holes behind the grill and it looks bad.
