Lets see your grills....
Is that a stull grille? Does it install over the factory plastic one? What emblem is that? Also, does anyone know what SS emblem to use if I was to install one on the back tail panel after filling in tne "CAMARO" letters?
Using Catz SR series lights roughly 5.5" diamater and under 3" thick. I used Gold irridum driving lights picked up on ebay for $45 (reg price is over $150). Ohh and there are 3 beam choices and several bulb and lense color choices. gold iridium bulbs, HID style bulbs, yellow lenses, fog, driving or spot lights.. blah... blah.. I had to make a custom bent bracket for each light and did trim a little of the styrefoam(sp?) and a corner of the bumper cover that was against the light. With the bit of triming there was a 1/4" or so gap around the entire light. Its a tight fit though!
First pic with No grille
Next with the grille in place
Third lights on with the grille
just figured I'd share since I've not seen any camaros with a large diamater fog light setup and I was told it could not be done because there was not enough space for anyhitng other than small lights. I'll get some pics tonight with the lights on.
My question is, if I wanted a "SS" badge for the stull grille, is the 1969 Camaro RS/SS the correct badge? Also, I wanted to make a smooth Berger panel and also install an old SS badge on that as well. Any ideas what badge to use there? It can't be flat.
Thanks again!
Thanks again!
Hope this helps.
http://media.vidiLife.com/video/2005...233/486490.wmv
Very unique.
