Relocating hood latch cable
Old Feb 21, 2006 | 08:25 AM
jks hugger orange ss's Avatar
Default Relocating hood latch cable
I remember reading on here a while back that you can relocate the hood latch cable for a cleaner engine bay. Any one know how to do this?
Old Feb 21, 2006 | 08:33 AM
Xsta Z 28's Avatar
I did it.
The cable is very easy to diconnect from the latch mechanism, them just feed back to the fire wall. It is awkward to work with, so be careful. Then just under the DS hood hinge there is a small seam/hole. I enlarged that hole and fed the cable through there, back to the latch. Similar to the wire mod, you need to take out the wheel well liner to guide the cable through.
Old Feb 21, 2006 | 08:40 AM
Thanks for the help!!!!
TNTramair's Avatar
very clean!!
Old Feb 21, 2006 | 08:49 AM
Xsta Z 28's Avatar
Here are some close up pics:
Above - where the cable and air tube go.
Below - from inside the wheel well.
Thanks for the props guys!
Old Feb 21, 2006 | 08:52 AM
Sweet looking car!!! Thanks for the exta pics!!
Also what kind of paint did you use to paint your valve covers?
Old Feb 21, 2006 | 09:07 AM
Xsta Z 28's Avatar
Exclamation
Rattle can paint . . . Use the Dupli - Color 500* Engine Enamel & Clear. I sanded the worst of the roughness and casting marks too.
Old May 31, 2007 | 01:01 PM
JayBirdWs6's Avatar
I know this thread is old but Im already done the wire mod I just need to do the latch mod now. I think I may do this, this weekend.
Old May 31, 2007 | 01:55 PM
fuel_junkie's Avatar
Sorry for the ignorant question but what does that hose go to again?
ps- love the bay-saving to bookmarks
Old May 31, 2007 | 02:07 PM
JayBirdWs6's Avatar
maybe the hose that goes to the airlid or egr stuff.
Old May 31, 2007 | 02:33 PM
SPECIALIZED STAINLESS's Avatar
When I re-routed mine, I just went around the bottom side of the wheel well inside the engine bay. You can't see it and don't have deal with going under like the wire mod
Old May 31, 2007 | 02:39 PM
schtick's Avatar
Looks like the hose that goes to the AIR pump (the thing that makes the high pitched whine..."kind of an electronic noise"....when you first start the car).
Old May 31, 2007 | 04:42 PM
Brian2006's Avatar
You didn't do this with the wire mod also did you?
I think this route may work better for black cars but any other color, the black cable may stick out like a sore thumb.
Old May 31, 2007 | 04:43 PM
No, I did the usual way for the wire mod
