Fog Lights
Old Feb 24, 2006 | 03:37 PM
LS1LUNATIC's Avatar
Default Fog Lights
I just got my hands on a set of foglights for a 98-02 Camaro. When I purchased my car, it came with no options so I never had the lights. I hooked up the switch to the wire in the dash above the radio, now when I go to hook up the lights, I only have one connection and that is on the drivers side. Am I missing a piece? Also do I need to put a fuse in the fusebox? It says on there fog lights, but when I look at it, the fuse isnt there and there are no wires running from it as it does from the other fuses. Any help would be greatly appreciated!
Old Feb 24, 2006 | 03:44 PM
LS69TA's Avatar
I didn't have factory foglights on my 02 Camaro either. I found some on Ebay, wired both lights together, and hooked up a relay to them. I used the parking lights to trigger the relay and send power to the foglights. That way I didn't have a switch to turn them off/on. Whenever the parking lights/headlights came on, the foglights did too, even when the high beams were on, the foglights stayed on.
