Orange halo's!!! PICS*
EDIT: I correct myself, our signal bulbs are not dual filament. They simply flash on and off. So it would be easy/safe to wire the halos to the turn signals.
The only problem I see in doing that is that at night when the DRLs are dimmed (get less power once the headlights are on) the LEDs in the halo's will be dimmer also. But once the turn signal is on they would blink the same way.
Ill check this weekend when I get a chance and figure out a wiring diagram so you could...
