Confused about white face gauges
Old Mar 1, 2006 | 03:00 PM
Justin01SS's Avatar
Default Confused about white face gauges
Just got my Macewen gauges in the mail and im a little confused as to how to get to the existing gauges in the car. The instructions in the box suck for one thing. It mentions some tabs that need to be depressed to get the lens out, but i dont see any tabs at all. Any one help with this? Thanks
Justin
Old Mar 1, 2006 | 03:26 PM
blown 346's Avatar
Did you get the new lens with the gauges? If not there are a few black push tabs you have have to push in, then pull the lens out. You hav to take out the whole cluster first.
Old Mar 1, 2006 | 04:17 PM
2K2WS6TA's Avatar
Assuming your 01 is similar to my 02, take the bezel (trim surrounding the guages) off and there are 4 bolts that hold the cluster in, remove them, and remove the cluster, you shoud now see what tabs they are talking about, remove the clear plastic lens, and install your gauge faces, assembly is the reverse of the removal
Old Mar 1, 2006 | 05:50 PM
BitViper's Avatar
Originally Posted by 2K2WS6TA
Assuming your 01 is similar to my 02, take the bezel (trim surrounding the gauges) off and there are 4 bolts that hold the cluster in, remove them, and remove the cluster, you should now see what tabs they are talking about, remove the clear plastic lens, and install your gauge faces, assembly is the reverse of the removal
1. Helps also if you remove the rear trunk release..it just pops out
2. The plastic sheeting piece it was attached to
3. Then undo the two bolts that hold the steering wheel shaft up.
4. Then with the steering weal outta the way..do the above and pull the cluster straight out
Old Mar 1, 2006 | 08:37 PM
Justin01SS's Avatar
Ok i didnt take out the cluster yet since i was unsure about these tabs. Hopefully i can get pics to yas tomarrow. Thanks for the info guys!!!
Justin
Old Mar 1, 2006 | 08:38 PM
Justin01SS's Avatar
Oh and did any of you do the macewen gauges WITHOUT the bezel? i didnt order the bezel so im curious to see what it looks like without it.
Justin
Old Mar 2, 2006 | 03:06 AM
nhra-trans-am's Avatar
Moderator
that's how i did mine
