VHT shade spray(need help removing reverse lights??)
Old Mar 2, 2006 | 11:13 PM
01bird58's Avatar
Default VHT shade spray(need help removing reverse lights??)
I tried applying VHT to the reverse lights but it keeps running on me no matter how little I spray. Any tips, or directions how to remove my reverse light covers. Thanks for any help.
Old Mar 3, 2006 | 01:19 PM
785T/A's Avatar
remove from the car or from the assembly? sand them a bit with 1500 grit wetsand paper. it helped with mine...
Old Mar 3, 2006 | 02:05 PM
1SicV8's Avatar
do u mean removing the vht? u can use lacquer thinner. that will take it off
Old Mar 3, 2006 | 04:04 PM
01bird58's Avatar
Ok ill def try sanding them a bit, I ment from the car i guess, thanks for the tip!
01bird58's Avatar
nope removing it isnt the problem, thanks though.
