Cleaning engine bay
Old Mar 3, 2006 | 11:15 AM
DrewSG's Avatar
Question Cleaning engine bay
I'm about to clean my engine for the time. I've already read the thread in the Appearance Hall of Fame. My question is, What areas should I avoid getting water into? I heard covering the MAF sensor, ECU, what else? Will get water into the alternator hurt it?
Any tips?
Old Mar 3, 2006 | 11:25 AM
2K2WS6TA's Avatar
I wrapped tin foil around the connector for the MAF, and the ECU, the alternator will get water in it, and may be a little low till it flings/dries the water out, then it should come back to normal,
Just don't use a full pressure stream, just a light mist will work, use some walmart microfiber towels to dry the bay/engine (they're great for that, and cheap enough to toss after you're done)
Old Mar 7, 2006 | 01:54 PM
02wS6firechicken's Avatar
Don't get a hard spary near the lower part of the intake. There is a bulletin (I'm a GM technician) about water seeping past the knock sensor plugs and filling up the holes they sit in. I accidentaly did this and my SES light came on. I was about to replace the sensors and intake gasket ($150) but the light went out and has not come on sense. But just be careful.
