shift knob removal
Old Mar 4, 2006 | 07:44 PM
natronathon's Avatar
Default shift **** removal
Does anyone know how to remove the shift **** on an automatic? I am going to machine my own cooler looking one out of aluminum, and I am curious as to how i can take the old one off... Thanks in advance...
Old Mar 4, 2006 | 07:51 PM
227Hawk's Avatar
There is a small wire horseshoe shaped clip on the backside.(Dash side) It comes out with a small flat screwdriver.
Hawk
Old Mar 5, 2006 | 12:11 AM
Hawk
is that clip right below the shift **** its self?
Old Mar 5, 2006 | 03:11 AM
1QUIKWS6's Avatar
Active Streak: 30 Days
Yes, pull the shifter back all the way to make it easier & pry the clip out with a screwdriver - **** will come straight off.
Old Mar 5, 2006 | 04:59 AM
227Hawk's Avatar
AS stated above. The clip is located un a slol about 3/4 " from bottom of ****.
Hawk
Old Mar 5, 2006 | 02:31 PM
Mrs99LSS1's Avatar
I'm not sure if the T/A is different from the Camaro, but for the Camaro you have to pull the button off the top, and then there is a small white plastic lock inside you have to remove. Turn it a 1/4 turn and it should come out. Then you can remove the clip and it should come out.
