CAMARO Door Guard Delete?
Old Mar 22, 2006 | 10:47 AM
JoeyAnderson's Avatar
Question CAMARO Door Guard Delete?
I know this mod is exceedingly popular for you Trans Am guys, but what about us Camaro owners? I'm wanting to delete those ugly door guards.
If you aren't sure what I'm talking about, check out these pictures:
Has anybody done this before? If so - can you type up a quick how-to? Hopefully there will not be any holes left in the doors afterwards! Thanks in advance folks.
Old Mar 22, 2006 | 10:58 AM
Jassick's Avatar
i'm pretty sure it's the same as the Trans Am, just get it started then peel off the left over adhesive, goo-gone it, wash, and your done. There was an extensive write on it some where in here, but it's about 4-5 pages back by now i beleive.
Old Mar 22, 2006 | 11:14 AM
LS1 Sounds's Avatar
Removed mine using basically the same process described by Jassick. I heated them up with a heat gun before pulling off of the car to soften up the adhesive some. The pain in the *** part was removing the adhesive left behind after the moulding is gone. Rolling it off the paint with my thumb proved to be the most effective method on my 1998 (old adhesive).
Old Mar 22, 2006 | 11:18 AM
kyles2000z's Avatar
be sure to wear gloves when you try to roll the adhesive of the car, or youll probably get blisters. no, you WILL get blisters.
Old Mar 22, 2006 | 11:20 AM
88monte's Avatar
liqour enthusiest
i removed mine with a heat gun. i blistered my thumb removing the tape tho lol
sorry about the huge pic. im at work and i can not shrink it :-(
jbuerke142's Avatar
rip it off!
gloves are a good idea, blisters... ow
Old Mar 22, 2006 | 11:32 AM
kornfreak_401's Avatar
wow i never thought about that, it looks really clean, I'LL DO IT!!
Old Mar 22, 2006 | 01:04 PM
Wow, the car looks so much better without the molding. Thank you for the pics and replies folks - I'll post mine after this weekend's work!
Old Mar 22, 2006 | 01:26 PM
RoastEmSS's Avatar
i just did it last night, i used a blow dryer to heat the glue and fish line to get it started it, i never even thought about gettin blisters, it was real easy when the glue is warmed up, ill post up picks later, cause im also repaintin my calipers right now
Old Mar 22, 2006 | 02:12 PM
GEARHED's Avatar
If you put Jojoba oil on the glue when its warm it slides off with a terry-towel and won't leave scratches.
No blisters required.
Old Mar 22, 2006 | 02:25 PM
SSmokd U's Avatar
jojoba? Never heard of it? Where can I get it?
Old Mar 22, 2006 | 02:28 PM
GEARHED's Avatar
Grocery stores (pretty much anyplace with 'owie' stuff).
I get the 'radical free' kind for $1.89 for a 5oz bottle, it goes a long way and won't hurt the paint but get any sticky goo off.
Old Mar 22, 2006 | 02:36 PM
nhra-trans-am's Avatar
Moderator
do it. A very good mod for both camaro and bird owners
Old Mar 22, 2006 | 11:12 PM
SSmokd U's Avatar
I know I did this to my WS6 when I had it. Took the mouldings and the Trans Am off the sides. Looked damn good too. Had sore thumbs for a week though
Old Mar 22, 2006 | 11:26 PM
chupr0kabra's Avatar
I did mine a while back with a hair dryer and some dental floss. Makes it MUCH easier to wash, too.
-Mike
Old Mar 23, 2006 | 02:01 AM
MosesMcgregor's Avatar
Do It!
i will continue with the example pix.
Old Mar 23, 2006 | 02:03 AM
Dustin's Avatar
It pulls right off then you should clay bar that area to remove all the crap in the clear coat.
