How do you remove the AC vents on a TA?
Old Mar 23, 2006 | 09:04 PM
9silverbird8's Avatar
Default How do you remove the AC vents on a TA?
Just as it says. Im trying to install gauges in the vents, but I don't know how to get them off.
Old Mar 23, 2006 | 11:15 PM
anyone?
Old Mar 23, 2006 | 11:28 PM
Fad2blk_98's Avatar
Basically just pry them out. I used a flathead screw driver to put behind one side and losen it, then just gave it a tug and they pull out.
Old Mar 23, 2006 | 11:37 PM
BitViper's Avatar
My Camaro vents just pull straight out...
Old Mar 24, 2006 | 12:56 AM
TUMBLRws6's Avatar
i broke mine tryin to get them out...they are reallly in there...they have like spikes that stick into the vinal around them....pain in the butt to get them out. good luck
Old Mar 24, 2006 | 08:49 AM
I tried this and got absoltely nowhere............anyone else?
Old Mar 24, 2006 | 09:21 AM
CrawlinWS6's Avatar
Import Patrol
use a small flat head screw driver. They work like a toggle bolt. The whole in the dash they go into, gets larger in diameter as you push the vent in. So the sides of the vent clip into the larger section. So use the screw driver to pry the side alittle and pull.
