harwood hood blows
--The primary latch wouldn't bolt in because there was some epoxy overpsrayed where that little tab needs to poke through. Had to drill it out, but my drill is at my friend's house. Got creative with some self tapping screws to remove the excess material.
--The stock secondary hood latch (that you have to open by hand after you pop your hood) uses a 10mm bolt. Harwwod decided to tap their hood for another 13mm like the rest.....but they forgot that the latch's holes are only big enough for a 10mm.......So I now have to go and have the latch bracket drill presses out so it can accomodate a 13mm bolt.
--Finally, I was never told, nor have I ever read that you need to "trim" off some lip that is supposed to protect it during shipping. So much for a DIY in your gargage for your average car enthusiest.
Should have went with a VFN, but the moron hood only comes in pin-on
I read a bunch of theads about hoods and everyone with a harwwod was very satisfied with fitment. I guess they didn't say much about install though.
I am gonna put it on now without the 2nd latch for now, and see how it fits. I imagine it will fit like ****, until I trim that gay edge that is on it.
I read a bunch of theads about hods and everyone with a harwwod was very satisfied with fitment. I guess they didn't say much about install though.
I am gonna put it on now without the 2nd latch fo now, and see how it fits. I imagine it will fit like ****, until I trim that gay edge that is on it.
I ended up trading a coworker hood struts. His struts were worn out and wouldn't hold the steel hood up on his '87 IROC, and mine were fairly new and were to stiff for the Harwood hood on my Camaro. The worn out struts worked perfectly
FWIW: I have close to 8 hours of prep into my VFN Sunoco hood and it's no where near ready for paint yet. I havn't even set it on the car yet either. It's gonna look badass when it's done though.
I am sorry but that is ridiculous. Are the companies REALLY selling $400-$800 hoods that are such $hit???? I refuse to just accept that we should expect to have to do so much work to a "paint ready" EXPENSIVE product.
How do the companies get away with selling such garbage???
Mine is a full pin on that I got on a GP, so maybe they just said **** this and slammed it out the door. Most of my problem is in the cowl, not sure if it wasn't rolled good or what but I had to skim coat alot of low spots to get the shape of it even and consistant.
Also, my 8 hours of work would probrably take a real body guy 4-5.
--The primamry latch (that releases from the dash) was not in the right place. Even when installed all the way to the left of the bracket, The latch doesn't line up centered in the the little valley that in needs to fall into--> it is still rubbing on the right side of the valley when you shut it.
--Also, under the 10"x10" Harwood sticker they put on the top of the hood, WAS A GOOD SIZE SCRATCH that will DEFINITLY require bodywork to fill/smooth out. How convienent that they put their ****** sticker right over this ****** giant scratch.
I'm just gonna bite the bullet and pay a million dollars to a body shop to prep/install/paint this POS.
why don't you call them and tell them about it, they should be able to work something out with you.
The scratch hiding under the Harwwood sticker:
A random chip on the nose that will look bad unless filled before paint:
The hindges (multiple issues, see above):
That's an extra kick in the a$$ while they have you " bent over the hood of your car."
