DIY coil pack relocation
Old Mar 27, 2006 | 12:33 AM
00ls1's Avatar
Possible Scammer - Buyer Beware - Issues Unresolved
Default DIY coil pack relocation
what plg wires did you people use?
doug
Old Mar 27, 2006 | 12:42 AM
~JOSHUA's Avatar
I made my own brackets and wires. I used Taylor Thundervolt that came with one end and I bought the LT1 ends which plug into the LS1 coils. Crimp the end on when you get the right length. Mine are mounted inder the cowl.
You can also buy an MSD LT1 wire set. It will plug directly onto your spark plugs and coils. If I had to do it again I'd probably go that route. Black MSD's.
Here's a photo. You can see the coils missing on the driver's side. The breather is hiding the passenger side view. You can see above each valve cover under the cowl a glimpse of the polished relo-brackets. I'll try to take close-ups of the polished brackets under the cowl later on.
