Wheel problem.
Old Apr 13, 2006 | 12:20 PM
nossty1's Avatar
Default Wheel problem.
I have a set of polished TT2s and I let them sit for to long dirty and now it has what looks like black stains on them. What is the best way to get rid of that?
Old Apr 13, 2006 | 01:16 PM
Ling_650vette's Avatar
I'd try a solution of hot (not scalding) water and car wash soap first (but Im assuming you've done that already...)
Next I'd go to a AutoZone or Wal Mart and look thru the wheel cleaners they have there (Look for Meguiars Hot Wheel Multi-Piece wheel wash. Its a non-alkaline, non-acid formula designed to safely remove grime, grit and brake dust from all polished/unpolished aluminum,powder-coated, multi-surface or anodized wheels - also safe on all aftermarket brake components including calipers and rotors). You'll might have to dilute the solution with some of them (like 1 part cleaner to 10 parts water) but you should be able to use that to get the majority of that grime off the wheels.
Old Apr 13, 2006 | 01:51 PM
nossty1's Avatar
Thanks, I will give that a try tomorrow when I get a chance.
