I badly craked my lower seat frame (causeing it to lean back and flex) and had to hammer it back into shape and get it welded and reinforced. I'd recommend dissassembling the seat bottom to look for cracks or bends. You can actually dissassemble the passenger seat and swap the bottoms of the two seats (minus the tracks, keep the tracks on their respective sides). You need to dissassemble both bottoms (pull the cushion off the frame) and move the "threads clip" from one side to the opposite side (its the threads in which the non-lever side of the seat bolts). All the other bolt holes are tapped on both sites of the frame. I had to do this so that I could piece-meal a driver's seat togeter so I could still drive my car to work while my father's friend welded up the brocken seat bottom. I then used the repaired seat bottom (originally from the driver's seat) to reassemble the passenger seat.
Sorry I don't have any pictures, but once you start digging in, you'll see what I mean. Also, I have the base model cloth seats. I don't know if the leather seats are any different.
