Removing 3yr old vinyl??
Old May 22, 2006 | 06:30 PM
LS1carlos's Avatar
Default Removing 3yr old vinyl??
I've had stripes on my car for the past 3-4 yrs and the hood pieces are begining to come off at the edges. I was thinking about removing them and not replacing them. How hard is it going to be to remove them and is there go be a difference in the paint after I remove them, and is there a risk of the paint or clear coat coming off if I do remove them?
Thanks!
Old May 22, 2006 | 06:39 PM
nasty99WS6's Avatar
A hair dryer is your best friend. Heat and slowly remove. Shouldnt be a problem at all, but of course there are factors playing into paint fade, and clearcoat coming off..like has it been repainted, does it sit in the sun alot etc..
Old May 22, 2006 | 08:32 PM
1SicV8's Avatar
yeah might do more harm then good, itll look diff under the vinyl
like nasty said use a hair dryer, use a plastic razor blade
Old May 22, 2006 | 09:03 PM
LS1carlos's Avatar
Thanks, is there anything you guys recomend to do after the removal?
Would polising the paint be a good idea?
Old May 22, 2006 | 10:30 PM
nasty99WS6's Avatar
Actually I just used my fingernail..And yes, a light polish will work wonders if there is any difference in the paint.
Old May 22, 2006 | 11:08 PM
LS1carlos's Avatar
thanks!!
Old May 22, 2006 | 11:14 PM
LS1carlos's Avatar
Its about 100 degress down here, hopefully that helps a bit.
