Need To Install Clear Cornor Markers
Old May 22, 2006 | 06:35 PM
BigSlick440's Avatar
Default Need To Install Clear Cornor Markers
I got the clear cornor marker lights for the front bumper and i need to know how to install them, would i have to pull the headlights out to get down there? cause i cant get to them from the bottom, if anyone has ever did this let me know guys,
Old May 22, 2006 | 06:36 PM
NEED2SPEEDLS1's Avatar
i didn't remove my headlights when i did em. Its a tight fit but u can do it. took me a bit cause of the fit. It was a must to do cause when i bought it it was missing one of the markers!
Old May 22, 2006 | 07:00 PM
presto_z's Avatar
you can get from the bottom but you have to take off the black acess panels under the car i believe they are 10mm bolts... i recomend a power drill or air tool to take the time down cause your arms get tires after after the 10th one...ha...its a tight fit but they will fit, be carefull not to crack new lense...ive known people who cracked them, also dont bend the frontbumper cover to much or you may crack your paint.....it would be easiear to do from uptop w/ no headlights, when i put my halo's in i realized i should have done it that way
Old May 22, 2006 | 07:06 PM
Mike02Z's Avatar
If you have a Camaro it takes all of 3 minutes to take the headlights out so why would you want to spend a lot longer trying to go around that step? I'm sure it is more complicated if you have a TA.
Old May 22, 2006 | 07:46 PM
Ell Ess Won's Avatar
took 20 mins on the camaro. remove the lights, the clear corners are gonna feel like they are gonna break when you wedge them in around the corners, just push and theyll go in.
Old May 22, 2006 | 08:41 PM
1 SIC Z's Avatar
DITTO
