Seat Removal
Old May 24, 2006 | 08:37 AM
4ced's Avatar
Default Seat Removal
How do you go about seat removal? Is it just a few bolts i need to undo from under the seat or is there a more complex process to do it? Im taking them off tommorow to clean up the whole interior but I thought of asking first so I dont get any suprises or break something by accident
Old May 24, 2006 | 08:45 AM
keliente's Avatar
Four nuts hold the seat down. Slide seat track forward, remove rear nuts. Slide seat track back, remove front nuts. If you have power seats you will need to undo an electrical connector underneath.
Old May 24, 2006 | 09:55 AM
BitViper's Avatar
I concur!
Old May 24, 2006 | 11:07 AM
FBDYLVR's Avatar
Also, the rear seats are held down by 1 15mm bolt on the seat bottoms. Once you get the bottoms out, the seatback comes out when you unbolt them on the hinge (either 13 or 15mm) and unbolt the seat belt holder.
Old May 24, 2006 | 11:27 AM
keliente's Avatar
Originally Posted by BitViper
I concur!
I concur that you concur!
Old May 24, 2006 | 12:01 PM
DirtyBird222's Avatar
ok so how in the hell do you get the plastic backing off the Trans Am Seats? Got the seats out trying to get these out to be dyed black!
Old May 24, 2006 | 03:42 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
The bolt in the rear seat cushion is a 13mm. They are all 13mm actually
