Sequential Tail lights?
Old Jun 18, 2006 | 04:06 PM
The1N_only's Avatar
Default Sequential Tail lights?
I know a few guys on here have done this, i have found this web site (www.webelectricproducts.com) that sells a universal type kit (sts-1)... Is there a write up anywhere, or could you explain more on the flasher and where i can get different ones, maybe even part numbers?
Old Jun 18, 2006 | 05:35 PM
Sick99WS6's Avatar
http://www.bfranker.badz28.com/fbody/sequential.htm
I have been thinking about doing this but not really sure what the big difference is between the basic kit and the full kit. If the basic achieves the sequencing, is shorter, and doesn't have the opportunity to screw up the tail light, why wouldn't you just do that? Has to be something b/c it comes with 2 harnesses and 2 more bulbs.
Old Jun 18, 2006 | 05:38 PM
Honda Hunter's Avatar
Intrested as well.
Old Jun 18, 2006 | 06:44 PM
Sick99WS6's Avatar
I shot Brent an email to see what the difference is. I think this is a sweet little mod.
Old Jun 18, 2006 | 06:56 PM
FBodyPerformer's Avatar
Ive seen it on a T/A before and it looked pretty nice.
Old Jun 18, 2006 | 08:16 PM
The1N_only's Avatar
is he on this board?
Old Jun 18, 2006 | 10:14 PM
BlackHawk T/A's Avatar
Subscribing...i've wanted to do this since I saw EVL LS1's car with the sequential tails.
Old Jun 18, 2006 | 10:29 PM
AltedZ's Avatar
My buddy has sequential tail lights on his 04 mach1, they are bad ***! Id recommend them to anyone, they are very cool in person. His also does the sequential lights when he hits the brakes, they are awesome. Im sure these do the same, maybe thats the difference in the kits, donno. Anyways, just thought Id throw out my input!
Old Jun 18, 2006 | 11:04 PM
Sick99WS6's Avatar
No but he is on CamaroZ28.com and I am a member there also. I should probably post this over there also.
Old Jun 19, 2006 | 12:51 AM
RrCoX22's Avatar
sorry guys... that's the gayest **** i've ever seen
Old Jun 19, 2006 | 04:20 AM
1QUIKWS6's Avatar
Active Streak: 30 Days
The difference between the (2) kits is:
Your stock tailights really only have (2) flasher bulbs within - the most inboard. The outer light in each tailight is a different type of bulb/holder and does not flash. The basic kit only allows the (2) existing flasher bulbs to sequence.
The full kit also includes new holders that must be wired in place of the current outboard lights that don't flash. This will enable your tailights to now have (3) flashing bulbs instead of (2). There are modifications that must be done to the tailight housing to accept the new/different style bulb holders.
I have the full sequential kit with all (3) bulbs sequencing. Just having (2) sequence on each side is pretty much a waste of time IMO - doesn't look anywhere as good as (3) on each side.
I can tell you for sure that if you go the full kit route you will also need an Electronic HD Flasher to replace the stock Thermal Flasher to make the sequencing look proper...
Old Jun 19, 2006 | 07:33 PM
Onyx Z's Avatar
werd.
Old Jun 19, 2006 | 09:16 PM
The1N_only's Avatar
different stokes for different folks
Old Jun 19, 2006 | 09:25 PM
The1N_only's Avatar
well i tried this e-mail (sequentialturnsignals@yahoo.com) which is the one on his web site but it is no lionger vaid or something.... it keeps comming back to me. i realy want to buy one of his kits..... Anyone know how to get ahold of him?
Old Jun 19, 2006 | 09:49 PM
AnimalSS's Avatar
I don't know guys… maybe on a Mustang (kinda retro) but, not so much on a LS1.
Old Jun 20, 2006 | 03:18 AM
1QUIKWS6's Avatar
I got mine from Scott Williams at blinkblink.com - been working fine for 3 years now...
-Jay-
Old Jun 20, 2006 | 07:02 AM
WhiteBird00's Avatar
Ungrounded Moderator
Actually, the basic and full kits are exactly the same electronically. Both will sequence three bulbs on each side. The full kit includes the extra sockets for the outbord bulbs. With the basic kit you have to buy them separately at your local auto parts store.
The sequencing of the brake lights is the default operation unless you connect an extra wire on each side to the turn signal wires behind the dash. This is because the module doesn't know if it's getting power from brakes or turn signals unless it has a separate turn signal input wire. I highly recommend using the extra wire for safety - otherwise it's confusing to drivers behind you when you put on your turn signal (one side sequences) and then step on the brake (both sides sequence).
I've had the STS-1 kit in my car for several years now and I often get comments about what a great mod it is. I've even had people follow me into parking lots to ask where I got them (including a BMW once).
Old Jun 20, 2006 | 06:37 PM
Sick99WS6's Avatar
I heard back from Brent and unfortunately, he said the guy who use to sell the kits has dropped off the face of the earth and said the same thing about emails bouncing back. he is going to delete his email on the page.
Old Jun 20, 2006 | 08:11 PM
Pewterpower's Avatar
I PM'd some of you guys. Anyone else that's interested, give me a PM.
Old Aug 2, 2008 | 09:13 AM
jedimaster71472's Avatar
Sorry to bump an old thread. I used this kit and liked it a lot. Only problem is one mof the modules burned out after a couple days. They're sending a replacement though so it's cool.
