ss spoiler instalation
Old Jun 20, 2006 | 11:20 PM
themack56's Avatar
Default ss spoiler instalation
i was wondering how do i conect the 3rd led light, im instalin the spoiler on my 98 z28, do i just pule the wires that went into the stock spoiler into the led wires or what, this is the part that im not sure, do i need resistors, plz help, thnx let me know
Old Jun 21, 2006 | 02:45 AM
Kewl_Blades's Avatar
when you pull the old spoiler off, the wires are on the driver side under the spoiler and route inside a little cubby hole. The connector should be wrapped in insulation tape (foam padding with one side sticky). Unwrap the tape, disconnect the wire leading to the old spoiler. Mount the new spoiler into the holes on the passenger side and when you slowly lower the driver side, connect the wire from the new spoiler to the wire still attached to the hatch/trunk. Re-warp using the same piece of foam tape and while lowering the spoiler into the mounting holes on the driver side, feed the wire slack into the hole so it does not get pinched when you bolt down the spoiler. Done. Get a friend and make sure all the led's on the brake bar light up.
