Manual Trannys.
Old Jun 28, 2006 | 02:39 PM
alex_lee88's Avatar
Default Manual Trannys.
Where can i find the plastic piece under the shifter boot? it is in the shifter... .
Old Jun 28, 2006 | 03:16 PM
Llust1WS6's Avatar
if you're talking about the plastic ring that clips the shifter to the console, then i believe you have to buy a whole new shifter boot. at least i have to. my plastic ring broke, and the ring was sort of sewn inside the bottom of the boot. i think i ended up getting a new one for my old Z for like 40 bucks new (the boot and ring). i got it at a local chevy dealership. hope that helps.
Old Jun 28, 2006 | 03:23 PM
Tudds's Avatar
You can buy the ring for about 12 dollars, search for the part #
Lust1, you have an extra boot?
Old Jun 28, 2006 | 04:02 PM
Llust1WS6's Avatar
nah... my last one was all torn up... i just replaced it entirely and threw the old one out. i didn't know you could get the plastic ring without a new boot... mine was sewn together so that the ring would not come out of the boot.
Old Jul 3, 2006 | 02:26 PM
alex_lee88's Avatar
whats the part number?
Old Jul 3, 2006 | 03:03 PM
porksoda's Avatar
Just buy a new metal one from Farmer2. He is a member on this site. Just search for his name and PM him with what you want. Plus he is cheaper!
Old Jul 3, 2006 | 04:59 PM
Charging TA's Avatar
My was cracked when I got the TA, just took a piece of metal wire, made a channel for it (soldering iron) and then spread the plastic over the wire (soldering iron)... used some epoxy also if I recall correctly. Knock on wood but its held up pretty well.
