Changing LS1 tail lights to LT1
Old Jun 29, 2006 | 10:28 PM
SPECIALIZED STAINLESS's Avatar
Default Changing LS1 tail lights to LT1
I really like the LT1 tail lights a lot better than the LS1 tail lights. Will the LT1 tail lights fit the LS1? Do I need to change the wire harness or something? Thanks, Steve.
Old Jun 29, 2006 | 10:50 PM
ROCNDAV's Avatar
They will fit (I went the other direction). I had to add a blue wirefrom the brake switch if I remember correctly all the ay back, but I dont think it affects you. If you do end up needing the rear harness, I got a stock LT1 style that I will sell you for $10, but I don't think you need it.
If you are going to sell you LS1 tail lights, you may get a little more for them if you sell them with you harness too
D
Old Jun 30, 2006 | 01:14 AM
Thanks for the info. I think I'll just keep my LS1 lights in case I decide to switch back for some reason.
So dose anyone know for sure if a LS1 > LT1 swap won't give me any problems? No extra wiring, or relocating?
Old Jun 30, 2006 | 01:38 AM
Well a quick search turned up this post: https://ls1tech.com/forums/showthrea...t1+tail+lights
Old Jun 30, 2006 | 02:47 AM
brynnda's Avatar
its just the cover, they will fit perfectly, nothing extra needed. ive done it in an ls1 and lt1, and i want ls1 lights. id trade you straight across for them. mine are in excellent shape!
