Will My Paint Get Damaged If
Old Jul 12, 2006 | 09:23 AM
osvaldo's Avatar
Default Will My Paint Get Damaged If
use something like scratch x on it too much? or any abbrassive for that matter? i keep reading that u need to break down such products so they sand or smooth out the clear coat...so does that mean that after a while of doing this thee clear cpat can be removed or damaged i guess?
Old Jul 12, 2006 | 10:18 AM
BlackHawk T/A's Avatar
Yes, but by the time you are able to cause any damage by hand you won't have any arms left...
Old Jul 12, 2006 | 12:50 PM
GETGONE's Avatar
You can go through the clear coat if you're using a really abrasive polish and do it often by machine. By hand it would take you quite a while unless you hit an edge often that could wear through quicker. If you're talking wet sanding to get rid of the factory orange peel then you do need to be careful because you can sand through the clear.
Old Jul 13, 2006 | 04:14 AM
silver98formula's Avatar
Wet sanding makes the car look amazing. Dont sand too much because before you know it there is no clear left. Just go slow.
Chris
