Little Button Under Glove Box
i believe the VIPER alarm system is the factory system,at least thats whats on the remote
ACCTUALLY DUDES ...ITS THE ******* AUTOMATIC LICENSE PLATE CHANGER...JUST IN CASE!!!!!!! HA HA........
I need to make a custom switch panel with a button labeled "trunk monkey".
I'd probably end up frying my gf cause shes usually the one tryin to make unauthorized changes to the stereo
also ..tire pressure... the tires are rated at 51psi yokohama 245 z 50s, the door panel says to go like 38 os something, i figured the 51 was too much so went w/40, should i bump the pressure up to the ntire manufactuers 51??, i am used to the regular 32 or so ..less for traction demands,thanks for the info
The button is for valet bypass for the viper alarm...you guys are a riot...thanks for all the razzing!!!
Either that or it's a "rear tire deflator" for better traction.....
Mine doesnt have one of those. Was it special editions only?
I haven't seen those ads in a while...
