Help, water vapor in tail light.
Old Jul 27, 2006 | 04:22 AM
17WITHaBIRD's Avatar
Default Help, water vapor in tail light.
I recently swaped my old lt1 tail lights for some honeycomb ones, and I noticed tonight that in the reverse light section on the drivers side only, there is some water stuck on the inside. Is there any way to get it out? Thanks.
Old Jul 27, 2006 | 04:40 AM
blown 346's Avatar
Re seal or replace the gasket that the socket for the bulb has on it.
Old Jul 27, 2006 | 06:36 AM
W8S SS's Avatar
dry it out really good with a blow dryer and do what blown 346 says
Old Jul 28, 2006 | 03:40 AM
Thanks. Will I be able to find a new gasket at my local parts store or do I have to take a trip to the dealership?
Old Jul 28, 2006 | 03:48 AM
blown 346's Avatar
Nope you can get one at your local parts store.
Old Jul 28, 2006 | 03:59 AM
6spd97ta's Avatar
i had same problem with mine. i took off the red reflector on the bottom and drilled three small hole facing up in each lens and so far no more water vapor of tail light fogging
Old Jul 29, 2006 | 03:50 AM
Is there any way that you can show me where exactly you drilled the holes.
