LS1 steering wheel in LT1?
Old Aug 2, 2006 | 06:41 PM
dcamcoz28's Avatar
Default LS1 steering wheel in LT1?
I'm sure this information is on the forum somewhere, but after countless searches I still can't seen to find any info. I have a 95z with a gross steering wheel that I want to replace. It seems to me that i'd have alot better luck finding a LS1 style in better shape, not to mention they just look nicer. What do I have to do to make it fit?? is it even possible?? any pics out there??
Thanks in advance!
Old Aug 3, 2006 | 02:05 AM
Pyro97's Avatar
If you are talking about the newer style like on the 02's then my guess is it should bolt up, however I don't know if the airbag will hook up right, I doubt it.
I have an 01 steering wheel in my 97, but I have the 97 airbag on it.
Old Aug 3, 2006 | 07:09 AM
herronz28's Avatar
firebird steering wheels did not change as drastically as the Camaros did in 2000. Our old bags will not fit on a newer style wheel.
The wheel will bolt up just fine, all the steering columns are the same 93-02, but the airbag...not sure of. Before you undo anything, remember to disconnect the battery! Don't want it to blow up in your face!
Old Aug 3, 2006 | 03:34 PM
RollTideTA's Avatar
PM'd you a place you can contact to find out for sure if they are a direct swap and possibly buy one if you like their prices
Old Aug 3, 2006 | 07:31 PM
Red97Z's Avatar
can you pm me the place too? I'd like to use a 02 steering wheel in my 97.
Old Aug 4, 2006 | 12:21 AM
RollTideTA's Avatar
PM sent
Old Aug 4, 2006 | 04:32 AM
6LITEREATER's Avatar
Just put a Trans-Am steering wheel of your same year in your car and swap out the air bag cover for the 2002 Camaro airbag cover... should be less airbag compatability problems.
