headlight help
Old Aug 16, 2006 | 01:16 AM
pyronotic138's Avatar
Default headlight help
i have the 1998+ body and my headlights rest on the bumer but also they dont tighten to a spot you can lift them freely with your hand about 1 inch and then they will just fall back down. is there a set screw missing or something.
Old Aug 16, 2006 | 04:01 PM
2001somws.6's Avatar
Open your hood and take the ruber covering off the manual adjustment. with a screwdriver and try adjusting it that way.
Old Oct 15, 2006 | 12:50 AM
please show me a pic. of what you are talking about
Old Oct 15, 2006 | 12:53 AM
Tainted's Avatar
look over the top of yur headlight with the hood up. theres a black cover with a long tube comming off it, behind the headlight cover. pull that rubber thing off and twist the ****. it manually raises and lwoers the lights
Old Oct 15, 2006 | 04:03 PM
jd783's Avatar
sounds like your headlight gaers are stripped theres is a guy on ebay that sells brass replacements i just installed them on mine and they work great think theyre $80 for both lights and come with everything you need to do them
Old Oct 15, 2006 | 04:10 PM
Tainted's Avatar
you dont need the brass gears yet. take uot the stock gear and flip it over. 180* of the stock one isnt used at all.
Old Oct 16, 2006 | 09:18 AM
soo my light finally failed me this weekend. passenger side motor will just let the motor run but nothing. gear finally died. also why when i lock my car with my viper alarm. i had this before when the passenger side light failed once before. but the driver side will lift up about an inch and go back down when i unlock or lock it. is that becuase the wiring is into the lights to flash their bulbs and it raises them just a tad for the amount of power it gets for a split second.
