Help needed !!!!
Old Aug 26, 2006 | 11:10 PM
1nastyss's Avatar
Default Help needed !!!!
I noticed today when i was washing my car that the bottom side of my front quarter panel next to the door where the panel bolts to the car is bent in pretty good on both sides, I know better then to jack it up on those tabs, i guess it happened before i owned the car, but anyways, what is the easiest and best way to fix it and will it move the quarter panel out farther than the door and mess up the gap......Let me know is it something i could fix or should i take it to a body shop
Old Aug 26, 2006 | 11:37 PM
99_Z_155's Avatar
if you are talking about the need to bend the tabs you shouldnt jack on, you can bend it with a pair of vice grips. just take it easy. thats what i did anyway..
Old Aug 27, 2006 | 12:06 AM
1nastyss's Avatar
should i take the bolts out first?
Old Aug 27, 2006 | 12:07 AM
99_Z_155's Avatar
i suppose you could, but i didnt. just take it slow so your plastic doesnt break. it just depends on how much that plastic is bent...
