question about stock body kit
Old Oct 18, 2006 | 09:46 PM
Searching4Sierra's Avatar
Default question about stock body kit
if i were to remove the stock z28 body kit would it have little brackets all the way around the car, or is it on with double sided 3m tape?
Old Oct 20, 2006 | 09:01 AM
LS1DER's Avatar
On the rear bumper yes. There is a metal bracket riveted all the way around. If you took the bracket off you would be left with a bunch of visible holes in the bumper. Everywhere else you would be left with a bunch of holes, but they are all underneath so you shouldn't be able to see them.
Old Oct 24, 2006 | 12:45 AM
2oo0sLvRz28's Avatar
I need a couple of pieces of the z28 body kit if you wanna sell any
Old Oct 24, 2006 | 09:05 AM
1FASTZ28's Avatar
The front pieces have brackets holding them on as well, so it would be the same on the front as the rear, I am not sure about the sides though.
Old Oct 24, 2006 | 11:10 AM
NxLS1496's Avatar
There are brackets on the front and back, but im almost positive the side skirts do not have brackets but they are still bolted to the body of the car. You can remove the ground effects and the brackets but you will be left with holes all around the body of your car.
