oven trick for turns/drls?
Thanks
its like there is not glue/sealant to even heat up. i think theyre like melted together or something, i dont know. but if you want to try and put them in the oven youll be fine. worst case scenario nothing will happen. but i wouldnt put them in any higher than 250 and i wouldnt leave them in any longer than 30 minutes.
Also, i think most of the haze happens on the outside. So here is what you do.
1) go to autozone and pick up some meguiars plastX. works great if theyre not severely hazed up. i reccomend using this with a the powerball.
2) if theyre bad then go to wal-mart, they sell a little 10$ dollar headlight restoration kit. all u need is a drill and i would buy some plastX to restore the shine. it comes with sand paper and everything you need.
3) there is a write up in the appearance hall of fame about this too.
4) you can always go on ebay and buy some clear ones, or night shade your stockers black, or just buy a used set for cheap.
