replacing door pin?
Old Nov 29, 2006 | 10:07 PM
sparky t/a's Avatar
Default replacing door pin?
my door drops down when it is opened and the pin is bent, it is really bad, i need to find a replacement and possibly a write up on replacing it.
thanks
Old Nov 30, 2006 | 12:16 AM
BLK_Z28's Avatar
Maybe a repair manual?
Old Nov 30, 2006 | 07:11 AM
*98Formula*'s Avatar
Simple, take the interior sail panel off and then you have access to the inner rear fender. Take a torx bit and unbolt it. Take the new one but it into the hole and hold the bracket with your hand and torque it down. Did this to mine many a times.
Old Nov 30, 2006 | 08:13 AM
NOBR8KSS's Avatar
You probably need to replace the hinge bushings as well...sounds like they are sagging.
Old Nov 30, 2006 | 09:32 AM
sparky t/a's Avatar
its more than a sag, the door literally drops.
and the pin im talking about is the one where the door hinges.
Old Nov 30, 2006 | 09:52 AM
kraaazymike's Avatar
I'd like to see this. You have any pics?
Old Nov 30, 2006 | 09:54 AM
sparky t/a's Avatar
give me a sec.
Old Nov 30, 2006 | 10:03 AM
sparky t/a's Avatar
while trying to get a better picture i noticed my problem goes a bit deeeper:
Old Nov 30, 2006 | 10:31 AM
You may be able to patch that door with A LOT of good fiberglassing, but Id look into replacing that door. That pin youre talking about is part of the hinge. You'll need a replacement hinge as well but theyre easy to replace.
Old Nov 30, 2006 | 10:33 AM
kny3twalker's Avatar
not sure where you are located but I can sell you a new door for a good price. I am in Dallas, let me know if you are close enough for pick up. I have to the hinge too I believe. And sorry about your troubles.
Old Nov 30, 2006 | 10:39 AM
sparky t/a's Avatar
im working on a sale right now for a silver door in georgia. im located in panama city fl. i knew the problems with this car before i bought it, still has a clean title and basically stole the car.
but how much are you asking for your door?
thanks.
