Help installing clears. How do i take off headlight?
and yes, on the 96 i just put the clears in from the bottom. i dont know if the nose is set up like that from the bottom on my 99 or not.
Not unless you are turning the aiming screws, which you don't need to do to remove the light assembly.
Not unless you are turning the aiming screws, which you don't need to do to remove the light assembly.You can TRY to seal up the clears.. But what most people do is drill small holes on the bottom of the clear corners for water to drain out and clear up any condensation. I have the older style clear corners (looks stock but clear) so I don't notice any fogging.
I still have stock ambers. Haven't tried that.
