paint looks like SH*T
so my question is, once you use a pc, and u use some swirl remover, and other products, does ur clear coat or paint become sensative or vulnerable(sp?) to damage?
or was it just all the rain and dirt that F'ed up my paint?
thanks a lot!
Are you sure you weren't using a mit or a towel or something that had been dropped in sand? What was your method of washing.
how do y'all go about washing ur microfibers, or whatever y'all use to dry ur cars?
I only use waffle weave microfiber towels (like this one from one of our sponsors: http://www.brilexsolutions.com/stwawe24x36.html) to dry the car. To keep them clean, I like to wash my microfiber towels separately, in the warm setting on the washing machine (liquid detergent only), and add a little white vinegar to the rinse cycle (helps keep them soft and release more dirt). Rinse them twice, then tumble dry on low heat. DO NOT USE FABRIC SOFTENER! It gets trapped in the fibers and makes the towels less effective.
Also, it might be a technique problem. If you're rubbing (i.e. using moderate to heavy pressure) when drying, you're increasing the chances of swirl marks. Fold the towel into a small square (just a little larger than your hand) and glide it over the surface. The towel should wick the water away from the surface. Turn/re-fold the towel often, to keep as dry a surface as possible on the car.
-Mike
I usually stay away from car washes with my Trans Am, I can count on my hand how many times I had to take it to the car wash last year. Also when I did I stood back quite aways when rinsing it down.
what kind of wash mit do yall recommend?
i've always thought that using wash mits or similar things would add swirls. those things look like dust traps. im afraid it will trap particles that will harm my paint.
no one there.
