Post pics of your battery relocation set up!
Old Jan 25, 2007 | 07:09 PM
FredoCamaro's Avatar
Default Post pics of your battery relocation set up!
Everyone post pics of your battery relocation set up! I would like to see the engine bay all the way to the battery!
Old Jan 26, 2007 | 02:24 AM
parbreak's Avatar
Here you go:
Optima Red Top in the wheel well:
Front Connection where Battery Tray used to be:
2/0 gauge wire used for + lead from battery through interior up to the engine compartment. 2 gauge used for - from battery to frame. 200 Amp inline fuse.
Old Jan 26, 2007 | 02:31 AM
Did you screw into the overflow tank to make the wireing stay flat like that? Is that the BMR tray?
Thnx David
Old Jan 26, 2007 | 02:35 AM
parbreak's Avatar
Believe it or not, the brass is held on by double sided tape. No problems with it either.
Old Jan 26, 2007 | 02:58 AM
Wow, I have a new respect for dble side tape ...lol Do you have any more pics of your bay area? Which battery tray did you use?
Old Jan 26, 2007 | 05:08 PM
Yahelou's Avatar
just curious, is there a reason why u relocated the battery? is it better for racing or is it just for looks??
Old Jan 26, 2007 | 06:13 PM
The main purpose is to move the weight (35-45 lbs) to the rear which allows for a better launch...
With my set up I don't wan't to have the empty space because it will look out of place. I wish they made a dummy battery that I could put there. I am trying to find some sort of box that looks like a battery cover. I have found a few but they are made to go in the trunk and they are huge and would be too large...
Old Jan 26, 2007 | 08:29 PM
87formy's Avatar
^^^What do you think of these? http://www.cardomain.com/shoplist~b~Optima~t~Battery+Accessories
I think they're covers for the optima batteries, but might look good if you just put them in there.
Old Jan 26, 2007 | 08:33 PM
osvaldo's Avatar
30-45lbs? will that make a difference? compared to the motor, 30-45lbs doesnt seem like much
Old Jan 26, 2007 | 10:18 PM
Those are kewl but I am relocating the battery...
Any weight you can remove from the front allows the front end to lift up more forcing the rear end to the ground plus the relocated weight is on the rear end also forcing the tire to the ground so it is a double advantage.
Some people need the space for fuel cells and what not, so there are other advantages for different applications…
Old Jan 27, 2007 | 01:32 AM
parbreak's Avatar
Mine was strictly for appearance reasons, however, yes 30-40 lbs is significant. Remember you're not only taking 30lb off the front, but adding 30 lb to the rear where it is beneficial. Net weight transfer of 60 lb.
Bryan
Old Jan 27, 2007 | 02:11 AM
tmc2k1's Avatar
Not to get off topic but, So technically is it better to leave the spare tire and jack in the rear or is it better to remove it?
Old Jan 27, 2007 | 02:34 AM
It is better to remove the spare tire/jack because you are removing 40 lbs that you don't need. Not sure on the exact calculation but I think it is something like every 100 lbs is a tenth of a second. With relocating the battery you are not loosing any weight you are just transferring weight... Think of it as swapping fat for muscle, you didn’t loose any weight but you can perform a lot better …lol
Old Jan 27, 2007 | 05:26 PM
76LS1BIRD's Avatar
Restricted User
I made this block to hook cables to, it fits into stock bat. tray
Note 200A fuse ,The tray was $10 @ NAPA
Dale (I have 1 of these for sale)
Old Jan 27, 2007 | 05:31 PM
KILLER-LS1's Avatar
you can very easily get an old battery and pull of the top. all of those lead plates will just pull right out. just wash it out and glue the top back on. we did that at kragen so we could have a display battery. and it weighs less than 1 pound
Old Jan 27, 2007 | 07:13 PM
That's kewl! I do have an old stock battery and I thought about that but I was afriad of burning myself with acid. Do you have any tips on a safe removal? Do you have any pics on the inside?
Thnx David
Old Jan 27, 2007 | 07:25 PM
http://i5.photobucket.com/albums/y19...d/100_0563.jpg
http://i5.photobucket.com/albums/y19...d/100_0586.jpg
http://i5.photobucket.com/albums/y19...d/100_0564.jpg
Sweet set up!
